wavegain problem
hi
I tried to download this software and use it but it stopped working after I used it once.i get the following message "wacegain .exe is not found"...is there a better software than wavegain that I can try?
lenny
Depends what you want to do with it. I use Adobe Audition for recording, editing and normalising, and it's very easy to use. If you want it for applying replay gain adjustment to equalise perceived volume, iTunes will do that.
S
thanks but I managed to install it..i wast tp normalize 78 recoreds and that's what wavegain was made for its also automatic..thanks much..
lenny
