XLR connections
la toilette
Downright stupid
Somerset
Recently bought a pair of Rogers LS5/9's, and they've got xlr connections on them - so just bought some female xlr's from Maplin. Having had a quick look on the web it seems that pin 2(+) and 3(-) are the ones to connect my speaker cables to, but I wanted to check with those who know before I do it.... :)
Presumably pin 1 (ground) is left unconnected...?
pin 1 earth, 2+, 3-, is the standard for low level signals,speakers can use any combination of the pins depending on the manufacturer,although 1 and 2 is the most common.you could use a 1.5v battery and briefly try each combination of terminals.once you've identified the 2 terminals check weather the cone moves in or out ,if it moves in the battery is + is connected to the speaker - if it moves out battery + is to speaker +
The beeb aint the only ones to swap hot and cold (2+3) around,the americans also had a habit for doing it .However the term xlr has nothing to do with the wiring convention,general consensus is its a military stores code,X for cannon,L for locking/latching ad R for rubberised
Thats news to me. Where does the rubberised bit come from?
