ZERO COSTââ'¬Â cable
materials
2 x 0.75 m polypropylene rope 3ply approx 6mm dia
1 x 2 m 35awg enameled copper wire
1 x 2m 28awg enameled copper wire
1 x roll PTFE tape
1 x various short lengths heat shrink
You will need to get four suitable RCA plugs.....
Note the copper wire, especially the thin one is very delicate.
The rope core is quite tightly wrapped with the finest copper wire in between the lays of the rope.
This has the effect of holding the wire and will keep the conductors evenly separated.
Leave about a centimeter clear at each end.
This is repeated with the thicker copper wire so that its on either side the thin one.
The PFTE tape can be used to mummy wrap the cable. This will give the cable some protection
I tend to put a couple of layers of heat shrink over the ends to give the RCA plugs something to bite on
Strip the ends of the copper wire with a stanley blade till they show bright copper pink, you may need to use a hand lens.
The thin wire is the signal or hot wire and the thick wire make the ground, then solder to your chosen plugs.
Repeat for the second IC.
They will need to be run in for a week before sounding at their best.
You can substitute silver for the copperââ'¬Â¦Ã¢â'¬Â¦Ã¢â'¬Â¦Ã¢â'¬Â¦..but if its uninsulated use ptfe sleeve. This can be held in place by ptfe tape.
materials
1 x roll PTFE tape
